Shock recommendations?
Old Oct 24, 2012 | 04:40 PM
PDX_Dakota's Avatar
PDX_Dakota
Default Shock recommendations?
I have a 2000 Dakota, 4.7L, 4x4 that needs new front and rear shocks.
I've searched and found a lot of info on shocks but not what I'm looking for. I would like to hear opinions and experiences with shocks from owners.
I'm looking for a front shock that is heavy duty and doesn't let the truck dip in the turns. For rear shock. I want a heavy duty one that holds up to towing, hauling dirt/sand/gravel (to the load limit) as well as some off roading (nothing major just off the path).
Also, what upgrades to hardware (bolts-nuts etc) should be done since this truck is 12 years old?
Thanks in advance.
Old Nov 3, 2012 | 10:08 PM
GEMAN's Avatar
GEMAN
I have some kyb's up front and some monroe load levelers in the back as i do tow a boat. The truck seems to like em.
Old Nov 3, 2012 | 10:26 PM
00DakDan's Avatar
00DakDan
Section Moderator
You'll get lots of opinions.
I have KYB's in the front, they're fine. I have Monroe Sensatrac's in the rear, no problems there either. I have hauled more than the limit, no problems.
I used to have KYB's in the back, hated them. When empty, it was so stiff it would bounce on rough roads and the rear would slide out.
Old Nov 4, 2012 | 01:02 AM
BCdakotaboy's Avatar
BCdakotaboy
I have Rancho 5000 series all around. They work well off road and have held up towing a 12 foot trailer full of dirt or quads. It a little stiff in the back with no load but I'll take that knowing I can load it rite up with no worries. I replaced all the mounting bolts with grade 8 strength.
Old Nov 4, 2012 | 03:33 AM
mmguy18's Avatar
mmguy18
Also have Rancho 5000's all the way around good shock tend to be a little stiff but work well.Got mine from Sum int Racing for $49 a piece.
