Dakota 5.2l v8 stalling
Old Oct 24, 2012 | 08:04 PM
Jeremy98dakota's Avatar
Jeremy98dakota
Default Dakota 5.2l v8 stalling
I have a 1998 Dodge Dakota 5.2L v8 and it stalls immediately in reverse and when coming to a stop. When coming to a stop the rpm falls to like 500 and tries to come back up then stalls. I replaced the IAC and it made it run better but didn't fix it. We took it to a shop and they hooked the computer up to it and said they couldn't find any sensors that were bad. Could it be a transmission problem? I am beginning to think so.
Old Oct 24, 2012 | 08:05 PM
bwdakrt's Avatar
bwdakrt
Sounds like a bad TPS sensor.
Old Oct 25, 2012 | 03:22 AM
dodgedakota98luver's Avatar
dodgedakota98luver
Mine was doing that a couple weeks ago and I just replaced the battery cable end completely took care of the problem. No code started good but had a stalling issue. Sometimes something that simple can be the culprit. Its worth a shot its cheap and easy
Old Dec 4, 2012 | 09:27 PM
Jeremy98dakota
Any more ideas on what this could be? How do you test the TPS and the crank position sensor?
Old Dec 22, 2012 | 03:04 PM
Jeremy98dakota
I finally fixed it. I ended up having to replace the CPS and that fixed reverse and I replaced the TPS and that fixed the stalling while driving.
Old Dec 22, 2012 | 04:52 PM
bwdakrt's Avatar
bwdakrt
All's well that ends well!
