Need help
Old Nov 4, 2012 | 03:01 PM
Icauto88's Avatar
Icauto88
Default Need help
Aloha,
I have a 2000 dodge dakota quad cab 3.9l v6 magnum 4x4. I have bin having some problems with my truck staling out. It idles just fine but when I press the gas the intake sounds like its sucking in air fast and it dies out. Sometimes it makes sort of a popping sound what seems like its coming from the intake. I have made sure all vacume lines are closed. It's not leaking fuel, and the injectors are working properly. I have had to bypass the purge selinoid so it idles properly. When I checked the fuel pump it wouldn't always come on. So I rigged a toggle switch and he pump works but sometime I have to tap the sending unit to get it started. I am wondering if it is a combination of things or if it could just be he sending unit. Please help if you can much mahalos for reading. Aloha
Old Nov 4, 2012 | 06:02 PM
Blacknights's Avatar
Blacknights
It sounds like your possibly having something partially blocking your air intake. Whether it is before your filter or for some weird reason after your filter. That could account for why it sounds like it is sucking in a lot of air and when you add more fuel the mixture becoming too rich could kill the engine as well. Stalling can be caused by a lot of things, so I can't say that will fix it.
Old Nov 4, 2012 | 07:54 PM
dodgeramguy85's Avatar
dodgeramguy85
Well it could be a problem of your fuel pump dying. I would get it tested to see what the psi is at. Also it could be a sensor on the throttle body. Like the tps.
Old Nov 5, 2012 | 02:37 AM
Icauto88's Avatar
Icauto88
Thank you both for your advise. I have already ordered another fuel pump so hopefully that fixes he problem and I can get my truck running again.
Old Nov 5, 2012 | 05:10 AM
cummingetit's Avatar
cummingetit
You didn't by any chance just buy a k&n air filter did you? I had something similar happen twice. Once i had bought a k&n filter that was waaaay over oiled and it actually starved the engine for air and died off like that. The other time i was driving in the rain with the home brew cai and sucked up enough water my filter that it starved for air and actually sucked my intake hose shut. Just an idea.
Posted from Dodgeforum.com App for Android
Old Nov 5, 2012 | 11:47 AM
Icauto88's Avatar
Icauto88
No I didn't. And I've even taken off the air filter housing and it still does it. I had bought an airtex E712MN fuel pump assembly. It was only 120 brand new.
