Brake lights wont work help!!!
I have a 2002 Dodge Dakota, I don't have brake lights. My hazards and turn signals do work. I have replaced the Brake switch 2x, I have tested for continuity in the brake switch between pin 1 & pin 2 and its good and when retracted there is continuity between pin 3 & pin 4. My bulbs are new. All my fuses have been replaced (Fuse 1,4,5).
I have replaced the Multi-Function switch and it didn't help my situation.
The issue had began when i bought the truck, the trailer harness was rigged to a cap light. I removed the trailer harness all together and reconnected the lighting harness in its factory position when i realized this could be the main issue ((that didn't fix my problem, however im not sure if it was the original cause)).
Any help would be greatly appreciated!!
