Hydraulic Control Unit thread Stripped
Old Jan 20, 2013 | 01:28 AM
98DAKAZ's Avatar
98DAKAZ
If you want it to be perfect like new you only have one option correct
As you said you dont want to mess with your breaks so bypassing the ABS is out
Old Jan 20, 2013 | 01:42 AM
98DAKAZ's Avatar
98DAKAZ
You can find them its if you can afford it thats all Dealer only part
http://www.mileoneparts.com/parts/2002/DODGE/DAKOTA/?siteid=214336&vehicleid=1384613&section=BRAKES&gr oup=ANTI-LOCK%20BRAKES&subgroup=ANTI-LOCK%20BRAKES&component=HYDRAULIC%20CONTROL%20UNIT
Old Jan 21, 2013 | 08:40 AM
thetalonguy's Avatar
thetalonguy
Hey guys, thanks for the info.
I was finally able to get the HCU out. I had to cut out holes in the plastic fender to get to the bolt heads.
Upon further inspection, the threads seen fine. They don't appear to be stripped. There is a possibility that I'm dealing with a bad flare bolt. I'm going to try a different brand and reflare the line.
Crossing my fingers. Will keep you posted.
Thanks
Old Feb 15, 2013 | 09:14 AM
thetalonguy
Just to keep you posted and for future reference... It was a bad flare nut. I ended up using the stock flare nut, reflared and tightened with a vice grip. No more leak and the brakes are tight as hell.
Thanks
