No Brakes!!
Did some more tinkering with it.
I bleed them all again.
Heres something I noticed. With the engine running, if i pump the brakes a bunch, the pedal gets tighter. As soon as I increase the rpms a bit, the pedal goes right to the floor, until I pump them some more.
Does this help at all?
I don’t see how that’s possible
I’m stumped??
I have only one possibility but this is just a guess the Power Brake Booster did you replace that?
I found this take a look LINK
Do a Google with this (how to tell if your power brake booster is bad)
I’m stumped??
This is probably not your problem but how do the flex lines look?
Have you done a full system Bleed/Flush
I cant remember but did you say you put DOT 4 in not DOT 3?
All vacuum lines are attached and in the correct place?
This is weird
This is weird
