4.7l oil emulsion question? pics*
Old Dec 7, 2012 | 10:51 PM
MadisonDakota's Avatar
MadisonDakota
Originally Posted by 00DakDan
I've NEVER had to turn on the heat to bring the temp down, even in 100+ weather with the a/c on.
Ditto.
Old Dec 7, 2012 | 11:56 PM
Wes Garrett's Avatar
Wes Garrett
Originally Posted by MadisonDakota
Ditto.
i ditto it aswell.. even with the 3.9 i never had a overheating issue, even with 235k
Old Dec 8, 2012 | 12:48 AM
rpowell's Avatar
rpowell
That was more than I had in mine, but yes these 4.7's seem to do that. Clean it out, do a light motor flush, replace pcv and only use good quality synthetic oil and you should be fine if it's running right. I am almost at 200,000 on my 2003. My truck runs great and gets factory or better mpg, so I know you can keep the sludge down. If your getting hot, definitely check out your cooling system and check for head gasket failure. I know with proper maintenance and preventative care these motors will perform and last. Hope this was helpful.
Old Dec 8, 2012 | 10:35 AM
rwilhelms's Avatar
rwilhelms
I've only had to turn the heat on once on the one trip and haven't had a problem since. I don't know if the cooling system was partially clogged and is now clear or what. My truck seems to run fine to me. I drive it 40 miles a day for work. The only thing I've noticed is a loss in gas mileage. It's not significant like a mpg and I'm just guessing it's because of the winter weather. I was always told that they put more additives in the gas during the winter here because of the cold but I don't know if that's true or just a myth that's passed along.
Old Dec 8, 2012 | 12:45 PM
MadisonDakota
Don't get me started on gas mileage.... lol
Have you checked your tire pressure?
