hydraulic tappets
Old 12-18-2012, 06:48 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
I think he was confused this is what he just said
but it is a V6, here in Brazil could not find the 2.5.
Plus the 2.5 dosent have a PCV valve so that makes it a 99 3.9 V6
Old 12-18-2012, 06:54 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Go here and see if you can contact this guy his name is chris1996
The link go to post #16
https://dodgeforum.com/forum/2nd-gen...uild-up-2.html
Old 12-18-2012, 07:14 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
At this time Im confused as to what engine he needs parts for
2.5 or 3.9
He has problems with English being from Brazil
But that part he shows is not from a 2.5L its from a 3.9L 2.5L have no PCV valve
Old 12-19-2012, 07:26 PM
chris1996's Avatar
chris1996
chris1996 is offline
Im here haha
for import them Im sure that you can use the local mail service but you should check and go to talk with them for see how can you import them.
98Dakaz which other car use the 2.5 from dakotas maybe they arent imported to Brazil but other car yes
Estou aqui haha
para a importação deles Im certeza de que você pode usar o serviço de correio local, mas você deve verificar e ir falar com eles para ver como você pode importá-los.
98Dakaz outro carro que usa o 2.5 a partir de Dakotas talvez eles arent importados para o Brasil, mas sim outro carro
Old 12-20-2012, 04:19 PM
thiagum's Avatar
thiagum
thiagum is offline
Originally Posted by chris1996
Im here haha
Estou aqui haha
Cris....ainda bem que encontrei um brasileiro...rs...minha dakota é 2.5 4 cilindros....ela tem sim a peça de pvc em cima do motor, mas nao sabem me informar o nome pra eu comprar....agora estou com problema nos tuchos hidraulicos, mas isso ainda nao é certeza, pois o mecanico ainda nao foi até ela pra verificar....
O outro cara foi de grande ajuda, mas pesquisando aqui no mercado livre, vi que a peça que ele postou é diferente da do mercado livre....por isso estou confuso!!....mas obrigado pela ajuda...vou esperar o mecanico e aviso certinho que peça preciso....
Old 12-20-2012, 08:06 PM
chris1996's Avatar
chris1996
2.5 or 3.9
he needs the upper part of the air intake the thing that goes over the TB I cant remember it name
Old 12-20-2012, 08:23 PM
chris1996's Avatar
chris1996
I'm not from Brazil but is easier to translate from Spanish to Portuguese English to Portuguese I'm from Costa Rica.
on your car if you're still not sure which part buy better diagnosis garage waiting before buying something wrong Dakaz is someone who knows a lot about the Dakota 2.5 and is telling you placed the pieces are not engine 2.5 and the plastic piece are looking TB cover but can not remember exactly as it is called
Eu não sou do Brasil, mas é mais fácil traduzir do espanhol para Português Inglês para Português eu sou de Costa Rica.
em seu carro, se você ainda não tem certeza de qual peça comprar garagem melhor diagnóstico de espera antes de comprar Dakaz algo errado é alguém que sabe muito sobre a Dakota 2.5 e está dizendo que você colocou as peças não são o motor de 2,5 e o pedaço de plástico são capa TB procurando, mas não lembro exatamente como é chamado
Old 12-20-2012, 08:42 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Thanks I hope he gets it understands
So he has the 2.5L engine is that correct?
Didnt know in Brazil its Portuguese they speak dont know much about Brazil except the strange movie by that name.
Link to the rockauto 1998 dakota 2.5L USA models http://www.rockauto.com/catalog/rafr...arcode=1314413
Old 12-20-2012, 08:55 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
This is my 2.5L engine is this what you need parts for?
Ignore the air box that says V8 Magnum
100_1382.jpg?t=1356054837
This is what it used to look like
100_0798.jpg?t=1356055321
Old 12-20-2012, 09:13 PM
chris1996's Avatar
chris1996
[QUOTE=98DAKAZ;2930127]Thanks I hope he gets it understands
yep he got the 2.5 but he doesnt know if he need those "hydraulic tappets"
also need the a TB hat that plastic thing i cant remember it name
Quick Reply: hydraulic tappets
