Check Engine Light.
Old Dec 18, 2012 | 11:22 AM
johndcarter1981's Avatar
johndcarter1981
Default Check Engine Light.
2001 Dodge Dakota Quadcab 4x4 automatic with a 4.7l v-8. Engine light came on. Checked the engine code via 3 ignition cycles and came up with P0031 which if I'm not mistaken is an O2 sensor issue.
I was just wondering if the code points to a specific O2 sensor or if it is more of a general "one of your O2 sensors is faulty"
Old Dec 18, 2012 | 11:46 AM
00DakDan's Avatar
00DakDan
Section Moderator
P0031 isn't in my FSM, for either 2001 or 2000 but, from what I can find it is Bank 1/Sensor 1, O2 sensor heater circuit low.
Check the oxygen sensor fuse in the PDC under the hood. It's not likely to be the problem as other O2 sensors are on it but it's worth a look.
Don't use Bosch if/when you replace the sensor.
Old Dec 18, 2012 | 02:00 PM
johndcarter1981
Just curious about why I shouldn't use bosch. Is there an issue with them in Dakotas? or is it a bosch issue in general?
Old Dec 18, 2012 | 02:26 PM
98DAKAZ's Avatar
98DAKAZ
The claim is the Dakota engines dont run good with them Im not sure if its all engines or some all I can say is my engine the 2.5L runs fine with Bosch both are bosch.
Old Dec 18, 2012 | 03:06 PM
00DakDan's Avatar
00DakDan
Section Moderator
If you check the forums you'll find lots of people have had problems and ended up replacing Bosch O2 sensors with others, in a very short time.
Especially on the 4.7.
Denso or NGK are preferred.
Old Dec 18, 2012 | 06:59 PM
moparman_2004's Avatar
moparman_2004
all the boshes i have ran i pulled out too the light comes right back on for not being within threshold and if you look online you can get them cheaper
Old Dec 18, 2012 | 09:05 PM
mmguy18's Avatar
mmguy18
Find best price for a o2 sensor has been Rockauto. $56 for a NGK upstream sensors
