Craptastic aftermarket shift lever HELP!
Old Dec 24, 2012 | 02:35 PM
alaskajeff's Avatar
alaskajeff
Default Craptastic aftermarket shift lever HELP!
One of the PO installed this ricer terrible aftermarket shift lever on the truck I just got. The OD button is messing up and I would like to return it to OEM. Is it that difficult to remove and replace? I found this on ebay:
http://www.ebay.com/itm/321039768296...84.m1438.l2649
THIS is what is installed now:
Any suggestions?
Old Dec 24, 2012 | 04:20 PM
Brian_'s Avatar
Brian_
is that plumbers tape, lol?!
Old Dec 25, 2012 | 12:32 AM
alaskajeff's Avatar
alaskajeff
Sure looks like it!
COME ON, ANYONE have any input?
Old Dec 25, 2012 | 02:06 AM
magnethead's Avatar
magnethead
I think it goes on/comes off easy, but not sure. Honestly too tired/lazy/wore out to look in the FSM. But I'll post it up when I get that far.
Old Dec 25, 2012 | 02:51 AM
magnethead's Avatar
magnethead
No mention of the handle, but I'm willing to bet it slides straight off. Page 1755 of the FSM.
Old Dec 25, 2012 | 03:02 PM
alaskajeff's Avatar
alaskajeff
Thanks, that helps when I get an OEM lever. I'll still have to figure out how to remove the aftermarket atrocity!!
Old Dec 26, 2012 | 12:27 AM
magnethead's Avatar
magnethead
my guess is that it'll slide right off.
Old Dec 26, 2012 | 01:50 PM
Jay87T's Avatar
Jay87T
probly crazy glued on or epoxied on.
Old Dec 27, 2012 | 09:19 PM
Dakota~N~Camaro's Avatar
Dakota~N~Camaro
Some of the rice junk like that will screw apart, like the carbon riceber will unscrew from the aluminum, below that there may be some allen set screws that attach it. Or it may be thereded on too. Channel locks or a small pipe wrench
Old Dec 28, 2012 | 02:54 AM
alaskajeff's Avatar
alaskajeff
I was able to remove it pretty easily. The top part with the non functional OD button screwed off and then the very bottom chrome piece screwed off as well. And the main center part had allen screws (as mentioned) that weren't even tightened down!! What a POS....Anyways,
If I touch the two wires together that are coming out of the lever the OD OFF light comes on. Then if I touch them together again it goes out. So that part works but my trans is STILL NOt shifting into 4th
