Dak won't shift into 4th
Old Dec 25, 2012 | 04:25 PM
mindcrash's Avatar
mindcrash
Unhappy Dak won't shift into 4th
So the winter came and apparently my dak's trany or something electric is afraid of the cold. When it gets below -23 it will not shift into the forth gear. Quite annoying. If anyone has ideas to what's causing it, any help would be appreciated.
Old Dec 25, 2012 | 04:46 PM
00DakDan's Avatar
00DakDan
Section Moderator
Many modern vehicles won't shift into higher gears until the transmission has warmed up. At -23, it can take a bit of driving, even then, it may not happen.
It's probably normal.
Old Dec 25, 2012 | 05:04 PM
mindcrash's Avatar
mindcrash
That may be possible.. however even after an hour of driving nothing happens. Then it would stay overnight and randomly start working the next day. I blame something electrical, maybe water got in..?
Old Dec 25, 2012 | 06:00 PM
alaskajeff's Avatar
alaskajeff
My 97 is doing the same thing. Is your temp -23 F or C?
I've heard it might be the shift solenoid.
Old Dec 25, 2012 | 06:10 PM
mindcrash's Avatar
mindcrash
Celsius, my friend. So, -11-12 F. Shift solenoid, hmm? I will check. I need this remedied this week. I have 2k+ journey coming up
Old Dec 25, 2012 | 06:38 PM
alaskajeff's Avatar
alaskajeff
Is your OD button working properly? I think the cause of MY problems might be the button on an aftermarket gear slelector I have. Is your CEL on? LMK what you find out.
Old Dec 25, 2012 | 09:00 PM
mindcrash's Avatar
mindcrash
HTML Code:
CEL?
For sure man.
Old Dec 25, 2012 | 09:10 PM
alaskajeff's Avatar
alaskajeff
CEL?
For sure man.
Does it flash when you get up to about 3K RPMs going between 55-60?
Mine is.
Old Dec 25, 2012 | 09:47 PM
mindcrash's Avatar
mindcrash
Nope, it does not.
Old Dec 25, 2012 | 10:45 PM
mindcrash's Avatar
mindcrash
So, I found something: people suggest warming it up in N rather than in Park. I'm going to test the theory right now.
