truck won't start, need help!
Old Jan 5, 2013 | 11:28 AM
RYCOMA79's Avatar
RYCOMA79
you need to check it at the coil. and you say you have spark at the coil or in each of the plugs
Old Jan 5, 2013 | 12:04 PM
Vladek's Avatar
Vladek
i pulled the wire at the coil and plug number 1, both have spark.
i also swithced batteries with my durango since it was just replaced a week ago. still no go.
Old Jan 5, 2013 | 12:11 PM
Vladek's Avatar
Vladek
by the way, thanks for the help guys.
Old Jan 5, 2013 | 12:16 PM
98DAKAZ's Avatar
98DAKAZ
I wonder if the distributor has gone bad I have never heard of any distributors going bad but who knows.
Or a timing chain jumped a sprocket I have heard of that happening it’s something that usually can’t happen but I have read of it happening
You have checked the Distributor Ignition Pickup correct if thats bad you will have no spark.
Or checked the Distributor Ignition Pickup connection for dirt or corosion pull it apart and get a good look at the terminals
Old Jan 5, 2013 | 12:26 PM
Vladek's Avatar
Vladek
i replace the ignition pick up and cleaned the connection. i have spark now. but still will not start.
Old Jan 5, 2013 | 12:31 PM
98DAKAZ's Avatar
98DAKAZ
I would say timing
So you now have
spark
a fuel pump that sounds like it works but I wonder if the injectors are firing do you smell gas?
Old Jan 5, 2013 | 12:37 PM
98DAKAZ's Avatar
98DAKAZ
This is so weird you dont remember anything weird that happened before this happened?
ran strange, knocking, strange smell nothing?
Old Jan 5, 2013 | 12:51 PM
Vladek's Avatar
Vladek
everything was fine before. no warning. engine ran smooth.
as for gas. i hear the fuel pump build pressure. plus i disconnect the fuel line right before the rail. it shot gas out like a super soaker.
so far i a have replaced spark plugs, plug wires, cap, rotor, pick up, crank pos sensor, and coil.
so,, at the this point. i am thinking it might be the pcm. since i really don't know what else to look at. and yes this is weird.
Old Jan 5, 2013 | 12:57 PM
98DAKAZ's Avatar
98DAKAZ
well unless you have towing coverage get a mobil mec to give it a try he may see what you dont
Old Jan 6, 2013 | 02:17 PM
RYCOMA79's Avatar
RYCOMA79
well I would pour a little gas down the throttle body and crank it over see if she fires. when she turns over does it sound like only half of it is moving. if the timing chain has slipped it will never run maybe never again. I would verify timing also check for 12 volts at injectors also check the resistance of all of them
