Pulls Left?
Old Jan 6, 2013 | 01:24 PM
98DAKAZ's Avatar
98DAKAZ
Many things could cause this but usually it’s something worn out but most shops will not do an alignment if there is any slop in the steering or suspension components
So everything up front is solid in great shape and everything in the rear is solid also?
Was the rear axel ever worked on?
Old Jan 6, 2013 | 01:30 PM
MadisonDakota's Avatar
MadisonDakota
I unbolted one side of it about 2 years ago. I decided against installing the lowering kit, and I put the 2/U bolls back. I don't remember if that's when the pulling started or not.
Old Jan 6, 2013 | 01:35 PM
98DAKAZ's Avatar
98DAKAZ
Now there is something I would check on I’m no expert on the rear axle if they self-align or you need to measure them and make sure both sides are exactly the same.
Something to check on
Also saging leaf springs on one side could do this or one side worn out bushings
Old Jan 6, 2013 | 01:40 PM
MadisonDakota
They have a pin that it self centered on. But...I could measure....where would I measure? lol
Old Jan 6, 2013 | 01:55 PM
98DAKAZ's Avatar
98DAKAZ
That I dont know check the FSM
Old Jan 6, 2013 | 02:39 PM
MadisonDakota
I don't see this being excessive?
More tests later.
Old Jan 6, 2013 | 02:43 PM
98DAKAZ's Avatar
98DAKAZ
I looked in the FSM and it looks like the axel is self-aligning.
That looks normal to me in the vid.
Old Jan 6, 2013 | 03:00 PM
MadisonDakota
I remember it aligning with little pins or something when I bolted it back up.
The rear brakes don't seem to drag, but my LSD makes it behave weird so I can't really get an accurate reading....or something. (I've never tested brake drag on a car with an LSD) I plan on taking a long drive today and seeing if one wheel is hotter than the other.
My only other options are tires (unlikely) and something being bent or a bushing being bad. (semi unlikely)
The truck only has ~75k on it... but i noticed an oil leak at the front by the big pulley? (harmonic balancer?)
Old Jan 6, 2013 | 03:18 PM
98DAKAZ's Avatar
98DAKAZ
If they are dragging some you should see some discoloration on the rotors it may only look like rainbow discoloration but a bad drag they will look blue black you can’t miss that.
rainbow
Blue black
Another Blue black one this one is more blue depends on how you look at it the angle
Old Jan 6, 2013 | 05:34 PM
MadisonDakota
Both of my rear brakes *might* look like that...I'm not too certain. I know I'm due for new ones anyway...
