TPS Question
Old Jan 10, 2013 | 07:35 PM
Jeremy98dakota's Avatar
Jeremy98dakota
Default TPS Question
If you accidentally install the tps backwards does it tear up the sensor?
Old Jan 10, 2013 | 08:52 PM
RYCOMA79's Avatar
RYCOMA79
maybe I don't think it would work at all as it can only rotate one way. if you did I think you would see physical damage even on the outside
Old Jan 11, 2013 | 12:16 AM
moparman_2004's Avatar
moparman_2004
how did you install it upside down? I didnt even think it was possible
Old Jan 11, 2013 | 07:58 AM
RYCOMA79's Avatar
RYCOMA79
I don't know if you can but you can put it in so the throttle plate tang is in the wrong position it will cause the sensor to jam and prob. break right away
