Old Aug 5, 2015, 01:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
HELP, parking brake release broken with parking brake left on
Old Jan 13, 2013 | 01:30 AM
Wes Garrett's Avatar
Wes Garrett
98dakaz,
if im not mistaken, its not a cable for the relase, it is a handle is plastic on a solid metal rod, wich when pulled it releases the pawl and relases the brake.. the best bet is to push down on brake just slightly, to take pressure off the pawl, and stick a flat head screwdriver in there and release the pawl, and let the brake release....
THE BRAKE PEDAL IS UNDER PRESSURE... IF RELEASING WITH SCREWDRIVER, GUIDE THE BRAKE PEDAL TO FULL RELEASE. IT COULD CAUSE INJURY IF RELEASED UNDER PRESSURE
Old Jan 13, 2013 | 02:16 AM
98DAKAZ's Avatar
98DAKAZ
Yes you dont want to be near the pedal as it will release. That info page is out of a 2003 only FSM Im just going by that as my Dak is a 98.
Im betting the release cable or pull rod is still under their find it and pull use logic and common sense.
Old Jan 13, 2013 | 02:24 AM
Wes Garrett
i couldnt agree more... but i decided to put that all caps disclaimer in there anyway for the few that dont use or have common sense.. i can say that most of us have learned to either not do, or how to do something, the hard way.. and that usually means the first time we did something odds are we didnt use common sense
Old Jan 13, 2013 | 04:00 AM
unatiq's Avatar
unatiq
Originally Posted by magnethead
Dakaz probably has a good shot of that area, I know I don't. But IIRC, the pedal should have a ratchetting mechanism on the top side of it, and the handle just removes the pawl and the springs pull the pedal back up. You should be able to take a straightblade screwdriver, stick it in the pawl, and have an asst push the pedal down to unload the pawl, lift it with screwdriver, then asst allow pedal to come up.
Yessss
this worked. thanks
there was no cable, i think it was removed but i dont get why the pedal was still stuck, i thought if there is no cable then the pedal should not stick to the ground anyways on the side there was this small lil lever which looked useless and i accidentally hit the screwdriver with and when i pulled the lever with my driver the pedal automatically started to release and then it was fully released.
Thats great. so happy with this buy
Old Jan 13, 2013 | 04:01 AM
unatiq's Avatar
unatiq
Looks like he fell asleep I like people that sound desperate but then vanish
I started to watch the 5th season of the office anyways thanks for your help guys, really appreciate it.
Thanks
Old Jan 13, 2013 | 04:03 AM
unatiq's Avatar
unatiq
Originally Posted by Wes Garrett
98dakaz,
it came up and released so slowly, if i would get injured by that then i deserve to get injured lol but i see what u mean cuz i was expecting it to shoot back up, thanks for the heads up though.
Old Jan 13, 2013 | 04:13 AM
Wes Garrett
any time man, enjoy your new dakota.. post up some pics of that gem when u can..
Old Jan 13, 2013 | 04:36 AM
magnethead's Avatar
magnethead
It may be sticky.
Normally, you pull that lever, sounds like a shotgun going off.
Old Jan 13, 2013 | 09:20 AM
98DAKAZ's Avatar
98DAKAZ
At release it should make a rather loud pop noise and quickly pop in the out position.
If not a few things to check the rear brakes they may be almost completely worn out and need new shoes or maybe the parking brake having no pull release hasn’t been used in many years and is a bit rusted up or just mucked up and needs lubrication.
I would check the rear brakes pull the drums off and get a look at them.
One other thing may be going on the rear brakes are way out of adjustment but this is also an indication of worn shoes
This is shown as the needed release Rod I dont think it includes the handel so you may need to make your own or junkyard http://www.factorychryslerparts.com/...2078977AD.html
$6
Old Jan 13, 2013 | 09:37 AM
98DAKAZ's Avatar
98DAKAZ
MOPAR OEM PARKING BRAKE RELEASE HANDLE FOR 2001-2003 DODGE DAKOTA
Look on ebay I have seen them
