How many miles do you have on your 4.7??
Old Jun 5, 2019 | 04:45 PM
  #21
jasonstl's Avatar
jasonstl
I'm pushing up on 200k on mine (I think I'm under 150 away, or close to it.)
The only things I've had to have replaced on the truck are the High Pressure AC Line, Power Steering Line, Starter, Transmission, and most recently, the Tensioner Pulley.
I've got a short list of mechanical things it needs still, but nothing TOO extreme that will keep it off the road longer than a day (I hope!)
Old Feb 11, 2022 | 06:54 AM
  #22
donalexinder24's Avatar
donalexinder24
Hello, I've done valve guide seals before, and the heads do not need to be removed.
Old Feb 11, 2022 | 09:11 AM
  #23
Check the dates on the threads you are posting in. Some are quite old.
Old Mar 27, 2022 | 08:54 PM
  #24
1000Blackcats's Avatar
1000Blackcats
189000 and change
Old Mar 27, 2022 | 09:33 PM
  #25
yuck623's Avatar
yuck623
197,000 no mechanical engine failure. Change oil about every 8K but use Mobil 1 and change the oil filter at 4K with ithe Mobile 1 filter or WIX.
Old Jun 26, 2022 | 08:48 AM
  #26
Rupoer's Avatar
Rupoer
Default 302K and she lives!
parked for 4 years under shelter with the plan of possible re n re clutch and body..corner n rockers.
Always a stickler for maintenance, some problems, under hood fuse box rot with back lights/ bolts holding coil pack down wrong materials..but 4 years parked, check oil throw a weak battery and she roars back to life! I was thinking timing chain and oil pump as well as clutch all lines all fluids...04, 1500, 4.7 with NV 3500(?) 5 spd. Amazing truck!
Old Feb 11, 2023 | 10:53 PM
  #27
mchl156's Avatar
mchl156
I bought my brand new Dakota in 2003 and it had 205,000 miles on it.
Old May 29, 2023 | 07:16 PM
  #28
greenhornet410's Avatar
greenhornet410
Default Not broken in yet
I’m the third owner of a 2002 2door sport & I have just over 32000 miles.
Old May 30, 2023 | 07:16 PM
  #29
mchl156's Avatar
mchl156
Default I have 203,000 on my 2003 Dakota.
Originally Posted by slow-poke
I have heard that the 4.7l is really reliable so i just thought i would see who has got a lot of miles on them and if you have had any trouble.
So post them up how many miles do you have on your 4.7?
Old Jun 1, 2023 | 06:51 PM
  #30
wigirl's Avatar
wigirl
Default 476,000
Orig engine & transmission
