2001 dodge dakota sport electrical problem
Old Jan 27, 2013 | 09:33 PM
demar27's Avatar
demar27
Default 2001 dodge dakota sport electrical problem
2001 Dakota sport quad cab 4.7L V8. The battery and the alternator are both brand new. I took the truck to the shop to have the electrical system tested and all cables were good and the voltage regulator is working. The problem is that the alternator is not charging the battery and the truck is not running on the amount of volts it is supposed to be I was wondering if I replaced the alternator pigtails would that solve the problem. Any suggestions would be appreciated.
Old Jan 27, 2013 | 10:48 PM
Crazy4x4RT's Avatar
Crazy4x4RT
So what are you voltage readings with the engine at idle and at say 2,000rpm and engine off?
I will move this to the 2nd generation Dakota sub-forum.
Old Jan 27, 2013 | 11:26 PM
demar27's Avatar
demar27
I believe it was at 10 or 11 volts either way it is at 2 volts short of where it supposed to be and it is only getting electricity from the battery.
Old Jan 27, 2013 | 11:33 PM
magnethead's Avatar
magnethead
Check the battery temp sensor under the battery tray. It will disable the alternator if the battery is over temperature.
Old Jan 27, 2013 | 11:35 PM
magnethead's Avatar
magnethead
That's not too far from normal if read at idle. My dash gauge falls almost to the red line at idle but goes to "normal" around 1700 RPM. I know idling in gear I only show 11.8 volts.
Old Jan 27, 2013 | 11:43 PM
demar27's Avatar
demar27
My dash gauge does that also but instead of going up it will drop down and the check gauges light comes on.
Old Jan 27, 2013 | 11:47 PM
magnethead's Avatar
magnethead
battery temp sensor is my first thought. I *think* it's the only determining factor whether the alternator gets enabled or not.
Old Jan 28, 2013 | 12:03 AM
demar27's Avatar
demar27
will check and if this helps any the trouble codes I got were p0622 and p1682
Old Jan 28, 2013 | 12:26 AM
magnethead's Avatar
magnethead
Within the FAQ -------- General Info, DIY, Engine Swaps, Lift + Lowering kit, Modification Ideas thread, is a link to the DTC codes.
P0622 Alternator Field Not Switching Properly
P1682 Charging Sys Voltage Too Low
Old Jan 28, 2013 | 10:45 AM
00DakDan's Avatar
00DakDan
Section Moderator
How did they test the voltage regulator? If the output is low, and you've got a code then there is a likely problem with it.
These code are from the 2001 factory service manual. Why they differ from what Magnethead posted I don't know. They're close though.
P0622: An open or shorted condition detected in the generator field control circuit.
P1682: Charging system output voltage low.
Unfortunately, the regulator is built into the PCM.
Start with the basics. Make sure all connections are clean and tight. Then, post back with what you are getting at 2000 rpm. Use a digital meter at the battery, not the one in the dash. It should be between 13.6-14.2.
