Lower Ball Joints
Old Feb 9, 2013 | 07:44 PM
hanleysh's Avatar
hanleysh
Default Lower Ball Joints
03' QC 4x4 5.9l I'm tackleing my lower ball joints tonight or tomorrow morning. Got everything apart just need to remove and replace. I have the ball joint press tool, anybody have any tips or advice for making this job go smoothly?
Old Feb 10, 2013 | 02:38 PM
jpayne80's Avatar
jpayne80
I have heard that freezing the ball joints will make them shrink a tiny bit allowing them to go in easier.
Old Feb 10, 2013 | 02:44 PM
98DAKAZ's Avatar
98DAKAZ
Good luck I have seen people on this forum that could never get them off and the same on.
Very PITA but maybe you will a lucky one.
Be prepared for plan B to kick in ASAP
Old Feb 11, 2013 | 10:54 AM
hanleysh's Avatar
hanleysh
Got into the job yesterday around lunch time, had everything tore down and back together by about 4:30. Didn't go to bad. Got the press set up on the bottom ball joints, heated the arm a little and got it to free up a smudge with the air hammer, then a little sweat and elbow grease and they came right out. Went back in fairly easy. One problem, grease fitting on my passenger side coulda been turned inward a bit more, I'll just make up some new swear words every time I go to grease it
Old Feb 11, 2013 | 04:36 PM
5hundo's Avatar
5hundo
OOC, which brand of replacement did you use? Moog? Raybestos Pro Grade? Something else?
Old Feb 11, 2013 | 07:06 PM
hanleysh's Avatar
hanleysh
Combo of moog and raybestos....Recently wrecked the dak and insurance paid for a new control arm and upper or the drivers side...I prefer raybestos, so that's what I purchased for the rest.....but my parts store gave me the wrong ball joints and weren't open on sunday to correct the problem so I wound up with moogs. So there's moog lowers and one moog upper and one raybestos upper.
Old Feb 11, 2013 | 07:08 PM
hanleysh's Avatar
hanleysh
And side note...did a side by side compare of the 2 brand new lowers(raybestos vs moog) I could hold the moog and move the peg on the bottom side but not with the raybestos...much tighter ball joint
Old Feb 11, 2013 | 07:45 PM
mmguy18's Avatar
mmguy18
Interesting to see which one holds up.
