modified 5.9L wont rev out (past 3000 rpm)
Old Feb 10, 2013 | 08:04 PM
Judd360's Avatar
Judd360
Default modified 5.9L wont rev out (past 3000 rpm)
My modified 99 dakota rt runs good at low rpms, but dosnt have any power at 3000 rpm or higher. Fuel pressure is at a constant 50 psi even under load. Tried bigger fuel injectors, computer, ignition, no luck. It has a 2800 stall converter. Any ideas??
Old Feb 10, 2013 | 08:07 PM
Tom A's Avatar
Tom A
Section Moderator
Restricted exhaust?
Old Feb 11, 2013 | 02:47 PM
Judd360's Avatar
Judd360
I checked out the cat....dosnt seem to be restricted, but I might remove it and see what happens. Thanks for the feedback.
Old Feb 11, 2013 | 07:56 PM
Judd360's Avatar
Judd360
Yep...ran a ba ck pressue test and sure enough it was bad
Old Feb 11, 2013 | 08:01 PM
Tom A's Avatar
Tom A
Section Moderator
Sweet! At least it's a relatively easy fix.
Old Feb 11, 2013 | 08:06 PM
MadisonDakota's Avatar
MadisonDakota
Old Feb 11, 2013 | 10:28 PM
Judd360's Avatar
Judd360
Yessir!! Runz great!!
