Differential Fluid Change?
Old Feb 16, 2013 | 10:55 PM
98DAKAZ's Avatar
98DAKAZ
I used gasket and RTV black no leaks yet
Worked great
I had a new plug for it also
Old Feb 16, 2013 | 11:09 PM
joe002's Avatar
joe002
Originally Posted by 98DAKAZ
...I had a new plug for it also
Did you seal it or just plug it in?
Old Feb 16, 2013 | 11:57 PM
moe7404's Avatar
moe7404
O YEA gaskets are great. i put sealer only on one side of the gasket, mostly the side that comes off when you that the part off.
Old Feb 17, 2013 | 01:12 AM
TheePlaymaker's Avatar
TheePlaymaker
Worked great
Where did you get your plug? I am trying to find a decently priced one since mine is leaking ever so little but still making the cover wet
Old Feb 17, 2013 | 01:20 AM
Tom A's Avatar
Tom A
Section Moderator
I don't use any sealer on the gaskets and they don't leak a drop. But I also have aftermarket covers on my differentials, so they're stronger and flatter than the stock sheet metal covers.
Old Feb 17, 2013 | 08:26 AM
98DAKAZ's Avatar
98DAKAZ
New plugs are from rockauto $2 +shipping but I think I got my plug from Autozone no didnt use any sealer on the plug no leaks from it.
I wonder if your differential breather is plugged up check it look for a small rubber hose coming off the diff going up there will be a small plastic cap on the hose thats the breather I made a custom breather for my Dakota
Old Feb 17, 2013 | 08:37 AM
TheePlaymaker
Thanks, I know when I changed my diff oil 2 years ago I didn't replace the plug and the wet part is just below the plug. I'll check the breather tho as well. Thanks
Old Feb 17, 2013 | 11:30 AM
joe002's Avatar
joe002
New plugs are from rockauto $2 +shipping but I think I got my plug from Autozone no didnt use any sealer on the plug no leaks from it...
OK, thanks for the info. I noticed that on mine the last time it was taken off they put the blue sealer around the edge and didn't know if that was the standard thing to do.
Old Feb 17, 2013 | 01:10 PM
98DAKAZ's Avatar
98DAKAZ
the plugs shrink after 8 or 10 years
Old Feb 17, 2013 | 05:38 PM
Tom A's Avatar
Tom A
Section Moderator
They also tend to get hard and crack. The last time I had a diff cover with that stupid rubber plug, I welded a 1/2" pipe bung in the hole and used a real plug.
