valve cover
Old Mar 3, 2013 | 08:01 PM
DakotaPower3's Avatar
DakotaPower3
Default valve cover
need to do valve cover gaskets has anyone done theres yet and do you recommend doing just the gaskets or replace the cover as well
Old Mar 3, 2013 | 08:05 PM
magnethead's Avatar
magnethead
the factory VC gaskets are re-usable, and do not normally leak. Your local O'R should be able to get felpro replacement ones (which are also re-usable)
there is no reason to replace a VC.
Old Mar 3, 2013 | 08:07 PM
DakotaPower3
ok i will check on the price when i go into work on tuesday
Old Mar 3, 2013 | 08:13 PM
magnethead's Avatar
magnethead
make sure the VC hasn't had a bolt come loose, where is it leaking from?
Old Mar 3, 2013 | 11:25 PM
DakotaPower3
its leaking right at the plugs
Old Mar 4, 2013 | 12:10 AM
magnethead's Avatar
magnethead
not sure what you mean. Is it leaking the whole length of the valve cover, or only around a few bolts?
Have you made sure the bolts are tight? Don't over tighten them. It's possible a cheap paper gasket was put in place of the stock rubber/urathane re-usable ones.
Old Mar 4, 2013 | 11:13 AM
DakotaPower3
its seems to be leaking the whole of the cover
Old Mar 4, 2013 | 11:23 AM
98DAKAZ's Avatar
98DAKAZ
All valve covers will start leaking as they age the gaskets shrink as they age just replace the gaskets no big deal.
