Opinions on 1/2 Impact
Old Mar 11, 2013 | 10:48 PM
mmguy18's Avatar
mmguy18
Lightbulb Opinions on 1/2 Impact
Need to buy a new 1/2 impact. Got a cheap one as a gift. I look it up the other day and here a few things about it.
Max speed 7000 rpm's
Max Torque 250 ft-lbs
Impact's per min 460
Needless to say it doesn't do well for me I think torque is to low. So wonder if anyone has a opinion the kinda impact I should look at? I do not use a whole lot so not looking to spend to much but when I do I would like it to work any kind of job. As a example needed to remove the nut to change my pinion seal and my current impact would not phase it.
Old Mar 11, 2013 | 10:51 PM
magnethead's Avatar
magnethead
Yea, it seems a little low. The cheap craftsman ones are 400 ft-lb.
It also depends on your air pressure. We have the big 2 stage husky pro, max 120psi and turns on at 90psi.
Old Mar 11, 2013 | 11:03 PM
mmguy18's Avatar
mmguy18
Found this one on internet for $42
7400 rpm's
400 pound torque
Max air pressure at 90psi
I have a 21 gallon 2.5 hp at 125psi air compressor
Old Mar 11, 2013 | 11:16 PM
Tom A's Avatar
Tom A
Section Moderator
I have this one. It wasn't cheap but it kicks butt.
Pretty hard to beat the price on that Craftsman one.
Old Mar 12, 2013 | 12:28 AM
dodgeramguy85's Avatar
dodgeramguy85
I have an old craftsmen(late 80's early 90's prob) I think its around 500lb torque. Tho you have to have a good compressor and air hose to be able to supply the pressure. I bought a harbor freight one couple years ago and I think it was 350lb/tq and I paid 19.99 for it. Check ebay for some.
Old Mar 12, 2013 | 01:53 AM
djibara's Avatar
djibara
best one I ever owned is made by MAC TOOLS kinda pricy but never had to worry about not getting a rusty nut or bolt off with it has over 500 ft pounds torque and is adjustable took lugs off a semi no problem with a 1/2 in drive impact pretty impressive if you ask me
Old Mar 12, 2013 | 02:06 PM
MadisonDakota's Avatar
MadisonDakota
http://www.harborfreight.com/12-in-p...nch-68424.html
Can be had for 69.99+tax with a coupon.
Old Mar 13, 2013 | 01:49 PM
mmguy18's Avatar
mmguy18
Look it up. Might just work puts out 700 lbs of torque at 8000 rpm's.
