Difference between lift and level?
If I was trying to lift a 98 dakota 2wd what is the difference between a 3 inch level and a 3 inch kit? I know a kit has springs and control arms but is that needed? What can the kit do that a 3 inch spacer can not do?
Thanks
Thanks
Naturally trucks are a little lower in the front than in the rear. Leveling kits normally include hardware for the front ie coil spacers for your 2wd but leave the rear alone. A lift would change both front and rear.
Is the 3 inch kit you're referring to perhaps a body lift? If so this just lifts the cab and bed off the frame. Looks bigger and allows for bigger tires but doesn't affect the suspension at all.
On a 4wd dak you can just crank the torsion bars and this will level the front with the rear.
