p0132 fixed now back again
Old Mar 17, 2013 | 10:10 PM
joker813's Avatar
joker813
Default p0132 fixed now back again
2000 3.9l got an upstream o2 fault fixed the o2 with a napa ntk reset com. now it back again please help all stock
Old Mar 19, 2013 | 05:10 PM
go-part's Avatar
go-part
Former Vendor
http://www.obd-codes.com/p0132
Check the wiring to the o2 sensor, you may have to buy a new o2sensor.
Old Mar 21, 2013 | 01:30 AM
DouglasWillard19's Avatar
DouglasWillard19
Mine's been throwing p0138. I'm going to check the sensor's circut out tomorrow. Im looking in to figuring out if (i know it sounds crazy) the o2 sensor is giving an accurate reading and the signal it sends is just that high of a voltage that it throws the code. I know i have intake problems, and my head gaskets have to be on their way out... so it is at least possible that the o2 sensor is just doin its job i guess?
Old Mar 21, 2013 | 06:53 PM
joker813's Avatar
joker813
iiiiii
Old Mar 21, 2013 | 07:01 PM
joker813's Avatar
joker813
sorry....i know its an o2 sensor.....high just means its reading rich. an intake leak or a vac leak will cause this code .i think i found why i was getting it . ground wire by ten. pully was loose and looks like runs into injector harness just crossing finger .
