Lifting....
Old Mar 18, 2013 | 01:09 PM
lonewolph's Avatar
lonewolph
Default Lifting....
I have a 1999 Dodge Dakota 2wd Reg Cab, and I have been thinking about lifting it with the 3 inch performance accessories kit. How hard is this to install though? Is there any welding required? I have done a lot of work on vehicles with my uncle but never anything such as a lift. I do not have access to a welder and don't know how to weld so I would want to make sure there is no welding required. I was also wondering if this would level out the truck as well? Would I need to buy anything other than the 3 inch lift kit? Thank you
Old Mar 18, 2013 | 06:20 PM
Custer's Avatar
Custer
This discussion has been started here at this link with an answer that may help - https://dodgeforum.com/forum/showthr...58#post2984658
Old Mar 18, 2013 | 09:41 PM
mmguy18's Avatar
mmguy18
Like Custer said you can use the other link. But the short of it is a body lift is pretty straight forward. 2 people can pull it off in about 8- 10 hours. This will only lift the body. If you want to level it you will need spacers for the coil springs on a 2wd. to lift the front and level with the back.
If you go to Performance Accessory web site there is PDF with the instructions on how to install and would give you a better idea of what you are dealing with.
Old Mar 19, 2013 | 11:36 AM
lonewolph's Avatar
lonewolph
thanks guys. I was also wondering with a 3" lift what is the biggest tire I could put on? I wouldn't put the biggest but just wanted to know. Also how big of a tire could I put on without the MPG taking a big nosedive?
Old Mar 19, 2013 | 08:03 PM
mmguy18's Avatar
mmguy18
31's I would say.
Old May 3, 2013 | 11:23 AM
BigDak's Avatar
BigDak
with a 3 inch body you should be able to tuck 33's but they wil rub, i have a 6inch suspension and 3 inch body and i put my body lift on in one day. you will get a steering linkage extender, and you will get all your blocks, you shouldnt have to extend any brake lines, i think 1 or 2 short lines thats it if any. i had to extend 2. other than that you will be set in a days work!!
Old May 4, 2013 | 12:42 PM
jpayne80's Avatar
jpayne80
I installed my 3" body lift on my 03 quadcab in 8 hours by myself. It is not difficult but with the amount of bolts needed to remove/install it is a slow process.
I have 285/76/16 tires and had to trim a little to make them fit. They do rub the frame a little but only at full lock.
Old May 4, 2013 | 04:23 PM
OttawaDakota's Avatar
OttawaDakota
i installed body lift last week, the hardest was removing front bumper, u do need to weld overload spacers in the box.
i put 315-70-17s yesterday, they dont rub but they only clear by 1/8th.
logically if i install a leveling kit, this will raise and make gapping better right?
ps i have 4x4 though
Old May 4, 2013 | 09:41 PM
sxrsil3nt's Avatar
sxrsil3nt
The overload spacers aren't really necessary.
I didn't install mine and I've had 1200 lbs worth of flooring, dirt, and river wash in it.
Old May 5, 2013 | 10:33 AM
BigDak's Avatar
BigDak
Ottowadakota if you just crank your torsion bars that would level it out for you
