Redlining before shift
Old Mar 26, 2013 | 03:45 PM
slaveinacubical's Avatar
slaveinacubical
Default Redlining before shift
2000 Dakota R/T 60000 Miles, all stock
I noticed one day that if I got on it WOT that I would redline before shifting. I figured I had a tranny problem so I changed the filter and oils. The problem was still there. I started scouring the forum and ended up trying to adjust the TV cable. No matter the position I still redline. What are your suggestion on where I start looking next?
Any and all help will be appreciated
Thanks,
-Keith
Old Mar 26, 2013 | 04:31 PM
Dodgeboy77's Avatar
Dodgeboy77
when i put in my fastman tb he told me to turn the truck to on, don't start, and after the lights stop push the gas pedal to the floor slowly then let it up and the start it. if that doesn't work the trans shop told me to adjust the tps voltage. there is a thread on here about that.
Old Mar 26, 2013 | 10:07 PM
slaveinacubical
I also have this "connector" looking thing hanging by the TB cable at the tranny. It doesn't seem to go anywhere...any ideas of what it is?
File Type: jpg
Old Mar 27, 2013 | 12:07 AM
Dakota Greg's Avatar
Dakota Greg
I thought at WOT its only supposed to shift at redline? Every automatc dakota I test drove from 97 to 02 did it.
Old Mar 27, 2013 | 01:05 AM
dodgeramguy85's Avatar
dodgeramguy85
Yeah what do you mean it will redline? On my 5.2 wot would shift at 4,800 then when I got my sct it bumped it up to 5,200
Old Mar 27, 2013 | 05:57 AM
magnethead's Avatar
magnethead
What they said. Now if it SITS on the limiter and doesn't shift till you let off, then you have a problem.
Old Mar 27, 2013 | 08:25 AM
slaveinacubical
Sorry, the only way it will shift is if I let off the throttle and ease back into it.
Old Mar 27, 2013 | 05:24 PM
slaveinacubical
What I meant by redline was the rev limiter kicks in and I have to let off to get it to shift.
I'm sure it's not a coincidence that after work today it did nothing but slip into gear, reverse and all forward gears. I'm pretty sure it was my terrible job at adjusting the TB cable.
Old Mar 27, 2013 | 09:15 PM
magnethead's Avatar
magnethead
From the FSM:
Originally Posted by FSM
THROTTLE VALVE CABLE
DESCRIPTION
Transmission throttle valve cable (Fig. 237) adjust- ment is extremely important to proper operation. This adjustment positions the throttle valve, which controls shift speed, quality, and part-throttle down- shift sensitivity.
If cable setting is too loose, early shifts and slip- page between shifts may occur. If the setting is too tight, shifts may be delayed and part throttle down- shifts may be very sensitive.
A correctly adjusted throttle valve cable will cause the throttle lever on the transmission to move simul- taneously with the throttle body lever from the idle position. Proper adjustment will allow simultaneous movement without causing the transmission throttle lever to either move ahead of, or lag behind the lever on the throttle body.
Old Mar 29, 2013 | 09:32 PM
slaveinacubical
Okay, throttle body lever and the lever on the tranny are in absolute sync. (had to use a camcorder, long AV cables and a TV to verify it but it is done.) Still have the rev limiter kicking in and some funny shifts happening.
What would you recommend next...pressure reg, speed sensor, band adjustment?
I know you have seen the questions hundreds of times and I appreciate you all putting up with me.
Thanks,
-Keith
