4.7 build mods
Old Mar 27, 2013 | 09:28 PM
Blacknights's Avatar
Blacknights
Default 4.7 build mods
Okay, I understand that this is a thread on the 3.9L however I'm also going to add in questions regard output on the 4.7L.
I haven't dynoed my truck yet so I'm having to do everything theoretically
I have an original 2001 4.7L, 235hp and 295 ft lbs. of torque
Modifications: K&N filter, Gibson exhaust, Fastman throttle body, NGK v-power spark plugs, 545FRE transmission, Superchip
Vehicle is properly maintained and just had Seafoam clean out the induction and fuel system, didn't have enough for the crankcase.
Does anyone have a math algorithm that could tell me how much my engine is outputing?
Old Mar 27, 2013 | 09:52 PM
00DakDan's Avatar
00DakDan
Section Moderator
I moved your post into it's own thread.
Old Mar 27, 2013 | 09:59 PM
magnethead's Avatar
magnethead
Stock:
3.660 bore x 3.405 stroke
Horsepower 230@4,600
Torque 290@3,600
For modeling, I'm going to use the Chrysler 273 small block, since the program I use isn't up to date for newgen blocks.
The closest I can get reasonably based on allpar's numbers is 224 @ 4500 and 284 @ 3500. Really not bad for a computer guestimate.
The K&N filter I can't really put in the system, I'd call it one on each scale.
With the headers, the numbers go to 249 @ 4500, 308 @ 3500
fastman TB, 250 @ 4500, 309 @ 3500
Superchips: 268 @ 4500, 338 @ 3500
Again, just computer guestimates.
Old Mar 27, 2013 | 10:50 PM
Blacknights
Okay thank you
Old Mar 27, 2013 | 10:55 PM
Blacknights
Originally Posted by magnethead
Stock:
Torque 290@3,600
So in the end it should be close to hp 280, tq 350
Any other suggestions, I'll eventually change the diffs to 3.92 or 4.10. I'm trying to get this engine to just squeeze out hp 300, I already reached my wanted tq number of 350 but another 10 or so won't hurt. I can still do a magnaflow cat, cams are too much, is there parts of the truck I can lighten up?
Old Mar 27, 2013 | 11:03 PM
magnethead's Avatar
magnethead
Any other suggestions. I'm trying to get this engine to just squeeze out hp 300, I already reached my wanted tq number of 350 but another 10 or so won't hurt.
That's everything added together, so that last number is where you're at.
the filter adds 1 and 1 roughly, the TB adds 1 and 1 roughly, headers add 19/18, programmer is worth 19/30 or so. again, computer guestimates.
Old Mar 27, 2013 | 11:06 PM
Blacknights
Weird considering I know the filter and tb both add a lot more then 1 each, those parts are both dyno tested
Old Mar 27, 2013 | 11:12 PM
magnethead's Avatar
magnethead
They may, but the computer can't comprehend that. All I can tell it is that the induction goes from ~450CFM to 525 CFM, figuring the filter is worth 25CFM and TB is worth 50. That's why I call it a guestimate.
Old Mar 28, 2013 | 08:02 AM
Blacknights
Interesting... hmmm okay. Thank you, well now I'm so curious I may pay the money for the dyno test. Also magnethead, would you have any suggestions of other stuff I can do to the truck?
Old Mar 28, 2013 | 06:16 PM
magnethead's Avatar
magnethead
A cam change would wake it up a bunch (Until you see the price tag), but that's all I can think of for a 4.7.
