Another 42RE Problem - FSM lookup request
Old Mar 28, 2013 | 03:54 PM
sxrsil3nt's Avatar
sxrsil3nt
Default Another 42RE Problem - FSM lookup request
I've got yet another tranny problem.
42RE, 3.9, 4x4, 57,000 kms.
I know that the 3.9 lacks power so when it comes to passing on the highway its definitely a pain in the ***.
Today I noticed that when cruising in over drive I could not get it to shift back down into 3rd without braking.
I wanted to pass a few vehicles a number of times and I would put my foot to the floor and it refused to downshift into 3rd to get a little more "umph", it just lazily stays in OD and it takes me forever to get up to speed.
Does anyone have a FSM that they could look up these symptoms for me, or does anyone know what might be happening?
My 42RE is garbage and its such a low mileage truck. OD seems to slam into gear and now I cant get it to buck back down to 3rd to pass.
Thanks in advance.
Old Mar 28, 2013 | 05:01 PM
Jdb107's Avatar
Jdb107
In my Haynes manual it says:
Problem:
Transmission will not downshift with accelerator pedal pressed to the floor
Solution:
Throttle Valve cable misadjusted
Try starting with that?
Old Mar 28, 2013 | 06:44 PM
magnethead's Avatar
magnethead
Problem:
Solution:
The TB valve doesn't affect the OD unit, it's fully electronic, and the PCM turns it on or off based on vacuum and TPS voltage I believe.
From FSM:
Old Mar 28, 2013 | 08:18 PM
sxrsil3nt's Avatar
sxrsil3nt
Thank you both.
Magnet, do you happen to know if there is an entry for a clunk into OD? Maybe I can try to narrow my problem down if they are some how related.
I appreciate it!
Old Mar 28, 2013 | 08:26 PM
magnethead's Avatar
magnethead
Originally Posted by sxrsil3nt
Thank you both.
I appreciate it!
as far as i know, a small clunk into 4th is normal as the OD unit is energized. mine does, at least.
Old Mar 28, 2013 | 08:35 PM
sxrsil3nt's Avatar
sxrsil3nt
Yeah I've read that in a few places, but mine will sometimes hesitate and then clunk into OD - definitely think something is up.
Once its in OD I drive fine until I want to pass someone and then it wont drop down to 3rd.
No codes either - my truck never throws codes despite having 5 things wrong with it.
Old Mar 28, 2013 | 09:08 PM
magnethead's Avatar
magnethead
something doesnt sound right...
Old May 3, 2013 | 10:11 PM
tspeed109's Avatar
tspeed109
I had the same problem and took it in to the dealer they replaced a fuse and a relay and it fixed the problem and never done it again. its been few years ago but the fuse looked burned at the connectors.
Old May 3, 2013 | 11:06 PM
sxrsil3nt's Avatar
sxrsil3nt
Thanks for letting me know tspeed. I haven't looked at any fuses or relays.
