lift kit helppppp
Old Apr 5, 2013 | 08:09 PM
  #21
Tom A's Avatar
Tom A
Section Moderator
I wonder if the person who owned it before you did some strange stuff with the springs.
Old Apr 5, 2013 | 08:15 PM
  #22
97dakota237's Avatar
97dakota237
can u take a picture of yours and show me what its apost to look like
Old Apr 5, 2013 | 08:18 PM
  #23
Tom A's Avatar
Tom A
Section Moderator
Mine has a 3/4 ton Chevy rear end in it with perches I welded myself, so it isn't going to help you much.
But the center pin (bolt) is supposed to look like this:
and just slip through the hole in the spring perch (with the nut on top slipping through the hole in the u-bolt plate).
Nothing should be bolted together, except for the leaf springs themselves.
Old Apr 5, 2013 | 08:31 PM
  #24
97dakota237
is the pin supposed to be going through the middle of the perch on the bottom side
Old Apr 5, 2013 | 08:36 PM
  #25
Tom A's Avatar
Tom A
Section Moderator
Yes, but it should come right out.
Old Apr 5, 2013 | 08:45 PM
  #26
97dakota237
yea going through the middle is a hex head i dont know what that guy could of possibly did
Old Apr 5, 2013 | 08:50 PM
  #27
Tom A's Avatar
Tom A
Section Moderator
Only thing I can imagine is that the hole in the perch is big enough for the bolt head to go through, but you're saying it's not.
Old Apr 5, 2013 | 08:55 PM
  #28
97dakota237
yea its not small enough to go through i dont know what i should do
Old Apr 5, 2013 | 09:00 PM
  #29
Tom A's Avatar
Tom A
Section Moderator
Sounds like your only option is to remove the bolt/perch assembly from the spring pack (remember the clamps), cut the bolt, and replace it with a proper spring bolt (or at least a hex bolt with the head ground round).
Old Apr 5, 2013 | 09:07 PM
  #30
97dakota237
my perch in welded on so how would i remove that with cutting that one off and welding a new on on
