Power steering
Old Apr 8, 2013 | 05:06 AM
thomasndeslongchamps's Avatar
Default Power steering
I have a 2000 Dodge Dakota 4 door quad cab 4 wheel drive 5.9 engine. Yesterday my steering starting getting stuck in mid turn. I checked power steering fluid and it's full. Any ideas what could be wrong?
Old Apr 8, 2013 | 12:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Apr 8, 2013 | 05:10 PM
moe7404's Avatar
moe7404
warning do NOT flush the pump with anything but oil. i saw a pump wiped out by flushing it with solvent, under power.
Old Apr 8, 2013 | 05:37 PM
00DakDan's Avatar
00DakDan
Section Moderator
There is a steering shaft with u-joints, it runs from the steering column to the rack. If the u-joints freeze up - which DOES happen, it'll bind up.
Replacement is the permanent solution. A temp fix is penetrating oil.
Old Apr 10, 2013 | 01:00 AM
Thanks guys but I found the problem. There was an old led battery cable end down where the u-joints are by the rack wedged in there stopping it from turning. Unbelievable. IDK how it got in there
Old Apr 10, 2013 | 09:19 AM
00DakDan's Avatar
00DakDan
Section Moderator
Glad you got it.
