Need New Shocks?
Old Apr 10, 2013 | 12:07 PM
jacobclif_9's Avatar
jacobclif_9
Default Need New Shocks?
After installing rear blocks and aftermarket cranked torsion bars, do I need to get new shocks in the front, rear, or both. Also what does it do? Is it a comfort thing, I've heard that cranking torsion bars makes for a stiffer ride, so can new shocks make it a smoother ride?
Old Apr 11, 2013 | 06:57 PM
hanleysh's Avatar
hanleysh
If your shocks are worn I'd replace them, but its not neccessary after the lift you did. If you do replace the fronts use a stock length
Old Apr 11, 2013 | 07:27 PM
bpark8824's Avatar
bpark8824
+1 hanleysh...
No, different shocks won't make a difference in the ride stiffness and you don't need to replace them from cranking the torsion bars.
Old Apr 11, 2013 | 09:29 PM
mmguy18's Avatar
mmguy18
+1 no need to replace yours if you don't them
