New truck with clunking sound on turn
Hi everyone. This is my first post here... I found the forums while searching for a fix to a problem I'm having with my truck. I just bought this Dakota a few weeks ago. It's my first one so I don't know too much about the vehicle yet...
I'm experiencing a clunking sound on turns. Definitely sounds like a steering system issue. It doesn't happen when driving straight, or on bumps, etc. Usually in a turn while decelerating or taking it a little sharp.
From searching this forum, it sounds like it could be either ball joint/tie rod/ sway bar/ or rack & pinion. Are there any other options? It sounds like the ball joints or tie rods are fairly easy to diagnose (jack up and check wheel play up/down and left/right). How about diagnosing the others?
2004 Dakota 2WD Club Cab with approx 82,000 miles.
Cheers
Cheers
Sounds like that about covers it. And yes, it's pretty easy to check all of those. Good luck and congrats on the truck.
Thanks. Can you point me in the right direction for diagnosing the sway bar or rack & pinion? Like I mentioned, I know how to check the ball joints & tie rods but not these other components. Especially the rack & pinion.
(e.g. should there be play in the sway bar & how much? and should there be any play in the rack & pinion & how to check for this?)
I had a similar problem with my truck, clunking from the front end when turning hard, usually happened in reverse like when backing out of my driveway or a parking space, it also happened on sharp turns while moving forward. It was hard to find the problem but it turned out to be a bad stabilizer bar end link (sway bar link).
Jimmy
Jimmy
Jimmy
Jimmy
Jimmy
Trending Topics
Well I did a quick check this afternoon... inconclusive. Jacked up the front end from under the control arms and wiggled left/right and up/down. There doesn't seem to be any obvious play but I only had 15 minutes to check.
If I wiggle left/right back and forth quickly there seems to be some play... I'll have to spend some more time on the weekend to do a more thorough check.
I'd like to check the rack & pinion while I have it in the garage and up. Can anyone walk me through the steps? thx
The sway bars and end links usually give a creaking or groaning sound. But just look at the bar and see if there is any gap between the bar and the bushings. If you can fit anything between the bar and bushing replace them.
You can't check ball joints just by wiggling the wheel. You have to jack the vehicle up and use a pry/crowbar under the spindle to see if you get any movement.
The OEM ball joints are non greasable and notorious for going bad early and with 82K I would be very suspect of the ball joints.
Good luck
Good luck
Good luck
Good luck
The sound seems to be coming from driver side on turns. It's not a single clunk, but I hear 2 or 3 clunks through the turn. Only on turns, and only on harder turns. If I slow to min speed and take the turn there is no sound.
So here's where I am:
- Upper ball joint seems tight with no movement. It is overflowing grease everywhere but it is brand new. Was installed when I bought the truck 4 weeks back as part of the safety.
- lower ball joint is original but seems tight with no movement.
- the sway bar links seems tight and solid with no movement.
- the left outer tie rod looks ok and it doesn't move.
- the left inner tie rod doesn't look great. Bellows boot is ripped and I feel play at the 3/9 oclock wheel positions. But the whole steering column moves with the play (video here:
