New stereo time
Old Apr 26, 2013 | 12:43 PM
BlueQC's Avatar
BlueQC
Default New stereo time
Hi guys,
My buddy used my truck to pick up his new outboard motor. Some Crack head ripped off my stereo.(&^^%$)~
My buddy did step up and pay for the window and the new stereo.
What color are the wires coming from the truck do I hook the new stereo to?
2001 Dak Sport 3.9L Auto.
Old Apr 26, 2013 | 01:03 PM
01SilverCC's Avatar
01SilverCC
Are the factory radio plugs still in the dash? If they are, all you need is to buy a matching wire harness that has the same wire colors as your new deck. Connect the wires, insulate any unused wires and plug it right in to the factory radio plugs. If the truck has the factory Infinity amplified system, be sure to connect the blue/white amp remote on wire from the new deck to the blue wire on the matching plug-in wire harness, otherwise you will have no sound. You can get the wire harness at any parts store, Best Buy or car audio store.
Jimmy
Old Apr 26, 2013 | 01:56 PM
BlueQC's Avatar
BlueQC
01silverCC
The factory plug has been cut off............
Old Apr 26, 2013 | 11:11 PM
01SilverCC's Avatar
01SilverCC
Here you go...
Constant 12volts + Pink
Accessory 12volts + Red/white
Illumination 12volts + Orange
Dimmer circuit variable 12volts + Tan
Infinity amplifier 12 volt remote on, if equipped: Dark green/red
Ground is the black wire with the 1/4″ spade terminal on the radio chassis
Left front speaker + Light green/violet
Left front speaker – Light green/dark green
Right front speaker + Light blue/violet
Right front speaker – Light blue/black
Left rear speaker + White/red
Left rear speaker – White/black
Right rear speaker + Tan/violet
Right rear speaker – Tan/black
Jimmy
Old Apr 29, 2013 | 07:16 PM
bpark8824's Avatar
bpark8824
You can always count on Jimmy when it comes to stereo/audio issues!
