Which trans-line feeds the cooling?
Old Apr 28, 2013 | 04:25 AM
sl2racer's Avatar
sl2racer
Originally Posted by cadipacer
OK!,, after thinking the rear tranny line is the inlet to radiator... when I looked both lines are the same distance in refference to front/vs/rear... so which line ON THE RATIATOR is the inlet line? TOP or bottom... I'm guessing top, as engineers would have fluid flow top to bottom.?
you will have to unscrew both and see which line shoots fluid. will only take a sec to figure it out. i want to say on my 4.7 2003 the top hose was the one i cut for the trans cooler. also i used the supplied rubber hose that was supplied with the trans cooler kit.
Old Apr 28, 2013 | 04:27 AM
sl2racer's Avatar
sl2racer
https://dodgeforum.com/forum/1st-gen...oil-lines.html
Old Apr 28, 2013 | 04:38 PM
cadipacer's Avatar
cadipacer
FROM ORIGINAL POST; I got it done,, oddly it turned out that the BOTTOM radiator LINE is pushing fluid into RADIATOR from the tranny.. so I cut the upper and continued to supply the aux-cooler.
(So my findings were the same as HYDROSHOCKERs in the link in red above)
Old Apr 28, 2013 | 11:40 PM
sl2racer's Avatar
sl2racer
that is what i said. you have to cut the top line for it to be the line after radiator going back to the trans.
Old Apr 29, 2013 | 05:15 AM
roy2486's Avatar
roy2486
I had the same problem with my cooler lines, 2003 Sierra, but I also own a transmission shop. The truck had 78,000 km on it and they wouldn't cover it at all. The crimps leak at the rad, I see this alot normally I just cut the line flare it and reclamp it with no problems but this truck was not old and under warranty after complaining I just repaired it my self. I will never trust GM and there warranties again. Dodge will be my next truck I've never had a problem with warranty on my jeep, they just fix it.
2013 MERCEDES BENZ SL-CLASS
Old Apr 29, 2013 | 07:21 AM
cadipacer's Avatar
cadipacer
Smile
SL2: yes you did say that,, I just read all the advise and forgot some..
I was bent on assuming fluid coming in the top and flowing to bottom.. thanks Phil
