P303 code comes and goes
Old Apr 28, 2013 | 02:49 PM
jodavisey's Avatar
jodavisey
Default P303 code comes and goes
I've had an intermittent P303 code for the past few months. I have swapped fuel injectors, changed the spark plugs and wires, distributor cap and rotor, coil pack, and even ran a can of sea foam through it. Any suggestions on where to go from here? Why is the code only intermittent?
Old Apr 28, 2013 | 03:46 PM
00DakDan's Avatar
00DakDan
Section Moderator
I moved your post into it's own thread.
What did the old spark plugs look like? How's the compression? If you rule out fuel and spark it could be a mechanical problem, maybe a burnt valve.
Old Apr 29, 2013 | 08:19 AM
sxrsil3nt's Avatar
sxrsil3nt
I had an intermittent cylinder 1 and 3 code.
Was my bank 1 o2 sensor.
Old Apr 29, 2013 | 11:37 AM
jodavisey's Avatar
jodavisey
The spark plugs looked ok to me, they had some gray ash on them, but no build up or serious discoloration. I checked the compression on the 3rd cylinder, it was about 125psi. I didn't compare it to the other cylinders or to the 3rd cylinder when the check engine light is off. I'll try to do that tonight.
