Help Me Locate a Clunk
Old Apr 30, 2013 | 09:16 AM
sxrsil3nt's Avatar
sxrsil3nt
Default Help Me Locate a Clunk
Since I've got this truck it will jump/clunk into gear when going from P to D or P to R.
Once in gear it shifts fine except for into OD.
Last night I had about 1100 lbs worth of flooring in the bed and I went to reverse out of a parking spot and it clunked and just died. Started up again and I was fine.
This morning pulling out of the garage I put it into D and again BANG jumped into gear, RPMs dipped but it didn't stall.
I originally thought tranny or motor mounts but from what I can tell they are fine.
Could it be tranny related? 42re with 59,000 kms
Thanks
Old Apr 30, 2013 | 08:15 PM
magnethead's Avatar
magnethead
shifter linkage, TV cable, and/or crank position sensor.
Old Apr 30, 2013 | 08:26 PM
sxrsil3nt's Avatar
sxrsil3nt
The crank sensor is new - I don't think its an issue with the TV cable as all gears shift fine once moving.
I just googled symptoms of a shift linkage failure but I'm not actually sure how I test it - any suggestions?
