Leveling a 97 4X4
Old May 1, 2013 | 10:04 PM
alaskajeff's Avatar
alaskajeff
Default Leveling a 97 4X4
Just finished installing some 2" lift blocks and new shocks in the rear. The U-Bolt brackets were SO RUSTED I had to grind them dowm and apply some POR-15 and paint before I reinstalled everthing. I think it came out pretty well.
Old May 2, 2013 | 12:37 AM
dirtbiker's Avatar
dirtbiker
Looks good man. Did you crank the torsion bars?
Also, on the topic of rust and the rear suspension... Take a look at your shackles and be sure they aren't almost rusted through. I wanted to lift my truck and since it's 2wd I had to get longer shackles for the rear. I'm glad I did, because the old ones were nearly rusted through. That would've sucked to have them snap while driving down the road.
Old May 2, 2013 | 12:40 AM
alaskajeff's Avatar
alaskajeff
No torsion bar crank that I know of, itkind of looks like it though? And the shackles are fine, just some surface rust. Thanks
Old May 2, 2013 | 10:58 AM
dirtbiker's Avatar
dirtbiker
I couldn't really tell. I think it would look good about an inch or two higher up front. I must've just gotten unlucky with my shackles. Or actually I was lucky I found them when I did lol
Old May 4, 2013 | 04:42 PM
OttawaDakota's Avatar
OttawaDakota
i did body lift last week and i have 1/8th clearance with 315s tires, putting a leveling kit would logically increase the gap right?
Old May 4, 2013 | 05:47 PM
Tom A's Avatar
Tom A
Section Moderator
You should probably post this question in a few more threads.
