Another 46RE transmission question
Old May 2, 2013 | 08:38 PM
jay.hampton's Avatar
jay.hampton
Default Another 46RE transmission question
New mwmber here. I have searched all the threads here to find an answer to the problem I am having with my truck. It is a 2000 Dakota quad cab 4x4 5.9L. I bought it over the winter. Everything has been fine with the truck until the last few days. I live in northern Il. We finally got a warm day on Saturday. I was driving home from work which is about 15 miles. A couple miles from home my check engine light came on, and then about 2 blocks from the house the OD off light and trans temp light came on. I checked the fluid with the truck in neutral, the level was fine. It is dirty, but doesn't smell burnt. A few hours later, I drove around town at different speeds for about 20 miles and couldnt get the problem to happen again.
Like a dummy, I pulled the negative battery cable and reset the code. Now yesterday on the way home about 8 blocks from the house, the OD off and trans temp lights came on again. No check engine and no codes. I let it sit a few hours and drove it. It ran fine and shifted well, but then when driving around in the small town I live in, sometimes it will shift through 1st, 2nd, and 3rd and then come out of gear. sometimes it will go back in, sometimes it wont. If I shut the truck off and start it again, it will engage like its supposed to but does the same thing. Not overheating though. Did the same thing in reverse. Sometimes it will engage, sometimes it wont. Still no check engine light or codes.
I pulled the trans pan, no metal in there at all. Checked the TCC solenoid with an Ohm meter like I found on youtube to do. 32.3 Ohms on one side, 32.2 on the other. Could this be the Governor Sensor Solenoid/Transducer, torque converter, or worse? Any Ideas???
Any help would be greatly appreciated!!
Old May 2, 2013 | 09:04 PM
00DakDan's Avatar
00DakDan
Section Moderator
Torque converter clutch? If it slips, it'll overheat the fluid. It'd be more likely to happen on the highway or towing than around town.
Old May 2, 2013 | 09:08 PM
jay.hampton
Thanks for the reply. I am not a transmission guy. Is the torque converter clutch part of the converter or seperate?
Old May 2, 2013 | 09:52 PM
00DakDan's Avatar
00DakDan
Section Moderator
The clutch itself is part of the converter.
I don't know if it'll throw a code or not, if the clutch is slipping.
Old May 2, 2013 | 10:14 PM
jay.hampton
Thank you. Do you by any chance know of any way to check the Govorner Pressure Solenoid/ Transducer? I found a video on checking the TCC Solenoid but not the other one.
Old May 2, 2013 | 10:19 PM
00DakDan's Avatar
00DakDan
Section Moderator
The governor pressure sensor can trigger a code if the solenoid isn't responding correctly.
You can download a factory service manual here: https://dodgeforum.com/forum/2nd-gen...-download.html
It needs to be converted to a pdf, you'll need a free utility, but it is the real thing and has all the transmission diagnosis charts.
Old May 2, 2013 | 10:24 PM
jay.hampton
Thank you so much!
