44re shift kit issue
Old May 3, 2013 | 09:51 PM
Mopar2108's Avatar
Mopar2108
Default 44re shift kit issue
Ok I put a shift kit in a few months ago, and have had the issue since I did it but my issue is that at any speed over 60 with WOT the transmission cannot find a gear to shift into. The RPMs hit 6 grand before I let up. Now when the tranny is not fully warmed up it does not do it.. I can keep it pinned to the floor with no problems.
So do y'all think it would be a TV cable issue or maybe a band adjustment issue? I adjusted the one inside the tranny but not the upper band. Thanks in advance everyone
Old May 5, 2013 | 02:47 PM
Mopar2108's Avatar
Mopar2108
*Update*
I have adjusted the upper band last night( Loosened the tighten nut and snugged the adjustment bolt all the way in, then backed it off 2 complete turns, then locked it in)... the roads were wet so i could not fully test it. This morning though i did test it and it seems it is trying to find a gear but is bouncing in and out of it. Still in need of advice though..
Old May 5, 2013 | 07:49 PM
moe7404's Avatar
moe7404
6 grand and no engine trouble? ill bet you weekened some parts. if it comes apart dont be surprised.
Old May 5, 2013 | 08:57 PM
Mopar2108's Avatar
Mopar2108
Yea it jumped that far before i could catch it.. didn't stay there for long. Im still tweaking it with the TV cable and the front adjustment band and its getting better.
