torsion keys crank or leveling kit
Old May 4, 2013 | 05:32 PM
OttawaDakota's Avatar
OttawaDakota
Default torsion keys crank or leveling kit
i put 315/70/17 on 3in body lift, i have 1/8th gapping with tires and bumper.
should i go with a leveling kit or crank keys to give me a lil bit more room.
any visual difference with the 2?
Old May 4, 2013 | 05:45 PM
Tom A's Avatar
Tom A
Section Moderator
A "leveling kit" is pretty much a torsion bar crank. If you only need like 1-2", you can probably get that from your stock torsion bar keys. Give it a try. You have nothing to lose.
Old May 6, 2013 | 08:33 PM
OttawaDakota
the truck is 2000, in canada, lots of wear and tear with winters, should i aim to get new ones?
Old May 6, 2013 | 09:29 PM
Tom A's Avatar
Tom A
Section Moderator
If you're determined to spend the money, knock yourself out. But you can probably get the same results without spending a dime. It costs nothing to try it.
