a/c issues
Old May 20, 2013 | 01:12 PM
sleepingiant's Avatar
sleepingiant
Default ac issues on an 02 dakota
Since winter up here just ended we have had a couple of wam days so tried my ac but nothing but warm air. When i turned th ac kn the clutch wont engage and when i put a test meter to the connector going to the compressor i get 0 voltage. I do have 13.5 volts on pin 87of the relay andall fuses are good. A friend put an gauge on the low side port from his red tek kit and it read 65. obviousky to high could this be why the compressor wont turn on. I f not any suggestions. T here is no low pressure switch on the acumulator but on e to the left of the rad and tied into one of the ac lines
Thks
Old May 22, 2013 | 06:27 PM
sleepingiant
Default a/c issues
02dakota sport
Compressor doesnt turn on
Jump pins 87and 30 on relay compressor runs
Low pessure side is 55lbs
Doesnt have low pressure switch but i believe it has low / hi pressure transducer near rad
Any ideas why compressor wont engaged
Thanks
Old May 26, 2013 | 11:43 AM
Brian in Tucson's Avatar
Brian in Tucson
Just a thought. The A/C might be controlled somehow by the pcm, have you checked your codes?
I have a 96, so my actual knowledge about your truck is nonexistant & I don't have a service manual. A proper service manual (like from Chrysler) might help you diagnose the problem.
Old May 26, 2013 | 10:51 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old May 26, 2013 | 10:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Old May 27, 2013 | 06:19 AM
98DAKAZ's Avatar
98DAKAZ
55 for low side is high dump some Freon and see what happens get it down to 45.
I live in Hot AZ and I have never gone higher than 45 or 50 for the low side
Remember this if using a Freon pump can in one the pressure reading could be off as much as 5 PSI
This is what I'm talking about one of these the pressure gauge is not accurate so 55 PSI could be 60 PSI
Old May 27, 2013 | 11:25 AM
00DakDan's Avatar
00DakDan
Section Moderator
I merged the two threads together.
Before you do ANYTHING hook up a real gauge set, high and low pressure gauges, so we can get an idea as to what the system is doing. The gauges on the cans are junk.
Both pressures are needed to diagnose the system.
