possible botched job...
Old Jun 4, 2013 | 08:48 PM
DouglasWillard19's Avatar
DouglasWillard19
Default possible botched job...
Ok so i replaced my intake manifold gaskets and valve cover gaskets on my 97 3.9. Took a while to get it fired back up.... but when i did... it runs rough as all hell and it backfires probably about 3 times every 5 seconds. I have no idea what the problem is so any help would be appreciated. Thanks. Doug
Old Jun 4, 2013 | 09:10 PM
Propwash's Avatar
Propwash
Sounds like you have a massive air leak between the throttle plate and the cylinders, causing a lean condition. Could be a mis-aligned gasket or a hose or fitting loose or not connected.
Old Jun 4, 2013 | 09:21 PM
DouglasWillard19
How easy is it to misalign a gasket? I was pretty maticulas when i put them in place. I made dowels out of the old bolts when i put the manifold down on it... it was one and done, no shifts at all. Thanks for the reply
Old Jun 4, 2013 | 09:22 PM
DouglasWillard19
When i put it in gear it dies right out
Old Jun 4, 2013 | 10:00 PM
00DakDan's Avatar
00DakDan
Section Moderator
Are the plug wires on correct? Correct firing order?
Old Jun 5, 2013 | 01:08 AM
DouglasWillard19
Yeah. I got the manifold back off... im pertty sure i jacked up the rtv job on th corners.
Old Jun 5, 2013 | 03:55 AM
re33ak's Avatar
re33ak
Trully don't know what happents with your car
