45rfe shifting problems
Old Jun 5, 2013 | 07:26 PM
countryjoe01's Avatar
countryjoe01
Default 45rfe shifting problems
i have a 2001 dakota 4.7 4x4 with the 45rfe tranny im getting a p0733 code inncorrect 3 gear ratio, ive pulled the pan and fixed the broken plate on the accumulators, but still will only shift 1,2 and go to n and rev i used a snap on scaner to activate each solinoid and found that when i activate the underdrive solinoid it slams in and out of gear all other solinoids engauge and hold i am thinking that it is a bad solinoid in the valve block has any one else had this problem?
Old Jun 6, 2013 | 06:53 AM
KillerKilgore's Avatar
KillerKilgore
Never heard of anything like this myself but anything is possible.
Like you said sounds like a solenoid bad, but I not a transmission guy
Brother had a Ford Broncho that you had to let off the gas to get it to go into
drive. Had it rebuilt at the shop and did the same thing. Warrantied so the shop rebuilt it again. Same issue. Shop guy said it must be something cracked in the transmission housing or something so THEY got a transmission from the junk yard and rebuilt it. no more shift problem.
Could your problem be something not lining up correct causing the solenoid to pop back out?
Just a thought.
Old Jun 17, 2013 | 07:52 AM
countryjoe01
Default update
found that when you activate the solinoids that it switches the ground on and off does not hold steady, i tested all the external parts and wiring everything passed i pulled the trany and found a burnt od clutch $150 for clutches and steals not bad
Old Jun 22, 2013 | 09:26 PM
countryjoe01
installed new clutches and steals back in shifts good total cost of trany rebuild was $200
Old Jun 22, 2013 | 10:38 PM
jpayne80's Avatar
jpayne80
The transmission is such a complicated beast to me. Props to your smarts and your ability to find and fix the problem!
