Bad gas mileage - 1999 Dodge Dakota 4X4
Old Jun 11, 2013 | 12:21 AM
magnethead's Avatar
magnethead
Originally Posted by damon5265
Yeah, that's true. I did do it several times and received a different number each time. On city I got a 4.3 MPG one time, a 5.? MPG 7.? MPG. I just put down the highest readings for city and highway.
put a full tank in and go from there.
The intake manifold on our trucks is 2 pieces. The belly pan gasket seals the 2 pieces. When it comes apart, it opens the intake manifold to crankcase pressure, allows oil into the intake manifold, messes up the MAP readings and fuel mileage and all kinds of wierd stuff.
Old Jun 11, 2013 | 12:54 AM
damon5265's Avatar
damon5265
Thanks everyone for the feedback. I think I will go ahead and replace the belly pan gasket, oxygen sensors, change oil, wires, plugs and all. It's due for it anyhow. I'll post my results.
Old Jun 11, 2013 | 01:43 AM
magnethead's Avatar
magnethead
For the plugs, use Autolite 3923.
O2's, use NGK's and NOT Bosch. Bosch's trip codes and are not compatible.
Servicing the distributor and belly pan gasket can't hurt. Gives you a chance to look at the lifter's, too. It's supposedly not hard.
Old Jun 12, 2013 | 11:09 AM
Robbadodge's Avatar
Robbadodge
I get the impression it could be the belly pan gasket, a quick search found this thread (there may be one on this site, too, but I didn't take the time to find it):
belly pan gasket
Good luck!
Robb
