The infamous NP231D... swap advice?
Old Jul 17, 2013 | 06:06 PM
giomi59's Avatar
giomi59
i'm not sure if any of those pics linked correctly... i had to upload them to Facebook and then link them because i didn't know any other way to get them on here. it said i was over my "attachment limit" or something.
here's a link to the whole album that you guys should be able to view even if you don't have a FB account.
https://www.facebook.com/media/set/?...1&l=9d10cde9e0
Old Jul 17, 2013 | 08:43 PM
Tom A's Avatar
Tom A
Section Moderator
Nope, still don't work. You need to use a hosting site like Photobucket.
Old Jul 18, 2013 | 04:25 PM
giomi59's Avatar
giomi59
yeaaaaa... i was copying the page URL, not the image URL lol. woops. got the original post edited though so they're in there and showing up now. for me at least...
Old Mar 22, 2020 | 01:35 PM
Ryne Miller's Avatar
Ryne Miller
Default Swap help
Ok I have a 99 Dakota the transfer case blew out the tag says 231d hd serial number 5210 5242 so I was told any 231d transfer case will work which is incorrect anyway I bought a used one the tag says 231d serial number 5209 8314 and it’s not the same the drive shaft out of my Dakota will slide right in but the transfer case will not slide in to the transmission all the way the shaft in the transfer is to long any info
Old Mar 22, 2020 | 09:06 PM
Possible difference between manual, and auto trans. Both cases came in the Dak, in both flavors. Probably the same as the full size trucks. (same transmissions as well....) The only difference between the d, and the dhd, is the width of the chain/gears. everything else is exactly the same. There were differences in the input hub between manual and auto trans, and various differences in shift patters, and provisions for VSS in the tailshaft of the case over the years as well. Makes it really fun to find one that will just bolt in.
So, what engine/trans do you have?
