1998 Dakota 318 needs heads, cam, exhaust combo
Old Jun 25, 2013 | 05:58 PM
pmckenna1's Avatar
pmckenna1
Default 1998 Dakota 318 needs heads, cam, exhaust combo
Hello everyone! I'm new to the Dodge community. I finally purchased a truck I had wanted since High School. So my 98 Dakota w/ a stock 5.2 and 5-speed will be built for general recreation, so I'd like to find a heads/cam/exhaust (Long Tube and true dual) that will work well together. I assume I will have to get a tuner as well. Any thoughts on a combo? Also, would an intake be critical in this combo? Thanks for your help, and if you want to point me in the right direction, that works too!
Old Jun 25, 2013 | 08:56 PM
Tom A's Avatar
Tom A
Section Moderator
I just want to say, I'm so jealous of anybody who doesn't live in California.
Old Jun 25, 2013 | 09:47 PM
atthewmartin114's Avatar
atthewmartin114
jegs has lots of headers. and depending on what your looking to do with it will depend on the headers and cam. intake i waould say go with the M1 its expensive but its the best over all i have found yet. the heads again depends on what you looking for if you was to hook to the boat and not drop below 60 climbing good hills go with a RV cam with timed back so your max tq and hp are around 3400 rpm. as for headers short headers build TQ long build HP also i found that the stock y is restricting and if you run the down streem further back in the exhaust it wont throw a cat code. when you punch the cat out. and im only running a glass pack and 3 IN single out the RR at 45 and i love the sound of my dakota 5.2 5 speed. (it rumbles not snaps like the 2.5 or 2.25 twin tails do.)
