fuel pump replacement
Old Jul 2, 2013 | 05:24 PM
fsr57's Avatar
fsr57
Default fuel pump replacement
i have 99 dakota 3.9 22 gallon tank do i have to remove bed or drop tank do not have help to lift bed off ,no shop.
Old Jul 2, 2013 | 08:06 PM
kingr00's Avatar
kingr00
I have not done it yet, but my understanding is that you can do either.
Remove two straps to lower the tank. Best to do with a near empty tank. Most work will be done on your back.
To remove the bed, there are eight bolts and three screws around the gas cap. You would either need a lift or friends to pick the bed up. From here, you can stand to do your work.
