01 4.7L idle issues
Old Jul 12, 2013 | 12:30 AM
JonCurry's Avatar
JonCurry
Default 01 4.7L idle issues
I have a 2001 4.7L 4WD that will not idle. You have to press the gas pedal a bit to start it, but when you release the pedal, the truck dies. I have replaced the IAC valve and was thinking that the TPS should be next. Any other ideas?
Old Jul 12, 2013 | 10:52 AM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
Do you have any codes? You can do the "key-dance" if you don't have a reader.
Starting with the key off, turn it to run (not start), off, run, off, then leave it in run. Any codes should display in the odometer.
Old Jul 12, 2013 | 11:44 AM
JonCurry's Avatar
JonCurry
No, It is not throwing any codes yet.
Old Jul 12, 2013 | 03:33 PM
Dakotaquad's Avatar
Dakotaquad
check ur crank shaft sensor mine did that for awhile also
Old Jul 12, 2013 | 08:15 PM
JonCurry's Avatar
JonCurry
Does the crankshaft position sensor effect the idle directly?
Old Jul 12, 2013 | 10:05 PM
Dakotaquad's Avatar
Dakotaquad
well my sensor was messed up to the point that the truck would start and start to studder and even stall out. the idle would jump up and down like it was on speed.
Old Jul 12, 2013 | 10:29 PM
JonCurry's Avatar
JonCurry
Thanks, Mine just flat will not idle. I will swap the crankshaft sensor, worth a try for $35.
Old Jul 12, 2013 | 11:02 PM
00DakDan's Avatar
00DakDan
Section Moderator
How's the fuel pressure? It could be a bad fuel pump. You can rent a gauge from Autozone to test.
It should be around 50 psi.
Old Jul 13, 2013 | 02:15 PM
JonCurry's Avatar
JonCurry
I will test the fuel pressure before I swap anything out.
