Another Problem Solved
I thought I would share a small success story with you. I know that some of you have had similar problems with your beloved Dakotas. My truck began to just quit running while I was driving it. It didn't matter whether I was at a stop sign with the truck idling, or driving down the road at 50+ mph the engine would just randomly die. It would always restart. I researched here and some stated the fuel pump could be he cause, but I checked the pump and it seemed to be working properly. Since I had had some issues with relays going bad lately (changed out two), I thought I would change the fuel pump relay. Since that change, the truck hasn't quit once. I have driven it multiple times without issue. Apparently that relay was having some type of a random issue. I thought this may be something that some have overlooked checking and a cheap fix.
Now I can focus on some other issues my truck is experiencing.
