axle cv joints
Old Jul 29, 2013 | 04:57 AM
DK Pony's Avatar
DK Pony
Default axle cv joints
2003 qc 4x4 4.7. 115k.
I replaced the ball joints ,tie rod ends, and all sway bar bushings a few months back. Now I am getting a popping noise from what seems to be the left front. It doesnt make any noise unless I am turning. I couldnt find any slop in the cv joints but I did find what seemed to be some slop at the axle splines at the diff .
would just replacing the axle shaft fix this or do I need to go farther into the diff.
Thanks.
Old Jul 30, 2013 | 09:05 PM
Tom A's Avatar
Tom A
Section Moderator
Thanks.
It's extremely rare for those splines to wear very much, and it probably wouldn't cause a popping noise anyway. Does it happen when you go around turns, or when you're going straight? Under acceleration or coasting?
Old Jul 30, 2013 | 09:58 PM
mopar_guy's Avatar
mopar_guy
I haven't worked on a ton of these, but I have seen it twice. The axle shaft is a harder metal than the CV part that fits over it and it won't wear very quickly but they can get chewed up a bit. I just changed the CV axle assemblies on my 2002 Dakota and I actually had to cut the CV assembly off of the axle shaft. I had pried on it so hard that the left axle shaft came out of the differential. I could see that the axle shaft had gotten hot, so I wanted to replace it. The left side axle shaft was $135 through my local Dodge dealer. The bearing and seal were about $40 more.
Old Jul 30, 2013 | 10:11 PM
Tom A's Avatar
Tom A
Section Moderator
Interesting. I have worked on a bunch of these and I've never seen it. I guess ya never know...
Old Jul 30, 2013 | 10:14 PM
mopar_guy's Avatar
mopar_guy
I think that it's just my bad luck.
